Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
When I turn on my faucet in the kitchen, I get a squealing/whistling type sound that gets louder the longer the faucet is on. Doesn't matter if it is hot or cold water that is turned on. What could this be?
Could be valve or pipe loose,have a look at the the valve pin and make sure the washer is tight or could be deposit build up in the mixer faucet.Basically just need a service and lubricate etc.........
