I've read all the posts about leaks, but I have the opposite problem. Both turning on and rotating for hot/cold needs incredible strength. "Oil" helps for a few days only. Apart from methods for fixing the "innards", where can I look for the name of the manufacturer, is it similar to the situation with locks - might I be able to buy replacement brass/valve bit only as the outer main tap is almost new?
Thanks.
Thanks.
