I just replaced a leaking copper cylinder on a pumped heating system, that has a Honeywell V4073A1039 Mid position valve. The hot water works fine, but the heating only works until the tank stat switches off but then works again if you set the programmer to HW off ie. then the pump cuts on and off with the room stat, so these are both ok.
I replaced the programmer but problem still exists, can this be the diverter valve?
If so why would turning the HW off fix it?
