strenghthening bath support frame
10 Jul 2010
Aberdeen
Bit embarrasing but here goes...
Basicaly im a fat b*****d and weigh 25st
Just had a new large Acrylic bath 1800x900 with amazonite coating fitted to downstairs (solid floor) bathroom.
The bath looks solid but the frame seems a bit flimsy, two metal strips across bottom of bath with four thinish metal screws fitted into the floor.
I stood in in before to shower and it creaked a little but was fine, but i was scared of lying down in a bath full of heavy water incase the legs bent or broke.
Is there anything I can do to give the bath some extra support?
My Dad suggested putting some bricks under the bath?Is this a good idea, or has anyone got a better one.
Thanks Ste.
Back to top
Alert Moderators
Display posts from previous:
Bit late now but should have gone for a steel bath, you could use a 2x2 frame to support all round fixed to wall where possible, should prevent embarrassment. :wink:
Bricks to support base are a good idea as they don't 'give' though the floor might. :lol:
Nowt wrong with lying down in the bath. At least your weight will be spread along the bath more than it would by standing up. :wink: :wink:
I use a product my employer manufactures which are flooring pedestals,these are steel adjustable supports which fit between the floorboards and the chipboard on the base of the bath.
make a 2"x2" framework and screw it to the wall and floor where possible ( yes i know its a concrete floor ) and yes you can use bricks although i would see if i could possibly fit some polystyrene between bricks and bottom of bath.
