Sub base to tile on ?
20 Jan 2005
Hi there - I have a chipboard floor in my bathroom and need to lay ceramic or travertine tiles. The chip board floor has not been laid very well and has a few minor gaps in.To remedy this I was planning on laying DITRA matting and then tiling over the top of that. I've never done this before so was looking for some tips ?
What do you use to stick the matting down with and will this work with a chipboard floor ?
Do you then just use a normal floor tile adhesive over the top of the matting ?
Any advice much appreciated.
Cheers
Thanks for the comments on this one, sounds like DITRA matting may not be the way forward for me.
So I am left with the following, a chip board floor with big holes in it where it's had to come back up for some changes in piping. Am I on the right lines below ?
Get rid of all the chip board and take it back to floor joists and then put ply down. If so which ply and what thickness is recommended ?
Once this is down I can then use a tile adhesive for wooden floors and then tile away ?
Or is there anyway I can put something thinner over the top so I don't have to pull up the chipboard which the builder nailgunned and glued down.........
Thanks in advance for help.
Fastmonkey
rip up chip board , treat joists with wood preservative , put in noggins to support joists/floor, screw down 18mm wbp ,
then fit underfloor heating if required ,
tile with bal adhesive /mudmix an grout
jobs a good un ,
if you use the search here you will find lots of indepth posts on doing this ...
hope this helps :)
Moz, please could you tell me briefly what noggins are? I'm still quite new to this game so, I really appreciate all the help I can get from you people ;).
Floor noggins on top etc :wink:
Thanks Masona ...;)
but imagine them upside down......on the face of the floor ...:)
2"x2" ...50mmx50mm battens
wedged between joist Tops, an as not pictured below so ply put down has another support too screw too ...
