Suitable roll insulation for sub-floor
6 Jun 2025
I want to insulate the ground floor of my house from the void below and my plan is to do it with wool insulation held up with netting. This seems to be a fairly standard way but I'm struggling to find insulation that is actually rated for the purpose. Everything from the usual shops (MKM, Jewsons etc.) seems to be rated for lofts or walls or be boards. I don't really want to use boards as (a) it's more expensive and (b) from what I've found it's more of a pain to put up. Has anyone done this themselves and can recommend a suitable roll?
I used rock wool slabs which only need a couple of lengths of wire stapled across the joists to hold them up. Given rough sawn joists you can cut the slabs a tight fit and they almost hold themselves up
I've done this, it works.
I'm curious why you want a rating for the purpose?
Using a membrane is a good idea because:
-A lot of heat is lost through the floor through simple air flow - a membrane can massively reduce this.
In terms of heat loss through a suspended floor, I wonder whether a membrane can make more difference than insulation.
-Warmer wetter air from the room can condense when it flows under the floor and cools. A membrane prevents this.
