    Dismiss Notice
Sunday night fun aka copper heating pipe leak in concrete .
Discussion in 'Plumbing and Central Heating' started by Benway, 14 Feb 2011.
  1. Benway
    Benway
    18 Oct 2005
    294
    Thanks Received:
    15
    Essex
    Country:
    Little background:
    Combi boiler that has been needing a ‘top-up’ every two weeks, so I had an idea there was a leak…… No leaking rads, no stains on ceilings, no puddles anywhere.
    Noticed the laminate leading to the kitchen had gaps appearing in it….
    Oh joy! Looks like the previous owner installed new rads with a greater centre depth than the originals and took the easy way out. It’s leaking from the tee. Water has made it about 30cm up the wall also so I’m guessing it’s been going a while.
    Not sure why there is a compression joint hiding in there also.
    Now my plan, unless there are better ideas. One of these:
    http://www.bhl.co.uk/product/SPEEDFIT_15MM_SLIP_TEE_CONNECTOR
    And one of these.
    http://www.bhl.co.uk/product/15MM_SPEEDFIT_15MM_PIPE_REPAIR_KIT
    In one of these.
    http://www.bhl.co.uk/product/HEP20_CONDUIT_JUNCTION_BOX_HX100
    Was thinking either a small section of pipe bending from the tee to the rad, or three 90 degree elbows and have pipe coming out of the wall to the rad.
    Yes/No/Maybe?
    Cheers in advance.
  2. Sponsored Links
  3. PEDANTICVINDICTIVEMAN
    10 Jul 2004
    12,598
    Thanks Received:
    2,623
    Country:
    Always some arsehole buries pipes with no protection at all, always bites someones arse even if it's years later.
  4. htgeng
    htgeng
    1 Jun 2004
    2,123
    Thanks Received:
    99
    Lancashire
    Country:
    without even removing the concrete you can tell whoever did that had no pride in their work - the radiator tail is on the pi** !
  5. bengasman
    bengasman
    28 Jan 2005
    34,181
    Thanks Received:
    3,124
    London
    Country:
    It has all the hallmarks of a cowboy job. Get a heating/plumbing insurance, you will need it.
  6. Whitespirit66
    Whitespirit66
    15 Dec 2007
    8,012
    Thanks Received:
    755
    Bristol
    Country:
    I would only ever attach push fit to new pipework, or pipes that are in good condition.
    Your pipes have been buried in screed, or whatever. You had to dig them out, then scrape the material off of them. I wouldn't then consider your pipes good enough for a reliable long-term seal with speedfit, as the pipe surface may be slightly damaged.
    Best to repair this with soldered joints, the only type of joints that should really be buried in solid floors.
  7. Agile
    Agile
    26 Jun 2004
    63,724
    Thanks Received:
    4,546
    London
    Country:
    There may not have been any of those specific things.
    But it looks as if the wall has had obvious signs of dampness for a very long time!
    I am sure that a simple pin type of damp meter would have innediately confirmed dampness.
    Tony
  8. Benway
    Benway
    18 Oct 2005
    294
    Thanks Received:
    15
    Essex
    Country:
    The fittings would be in a junction box, so not actually buried.
    So I could keep an eye on them for a while before putting the floor back.
    Not sure how good my soldering would be with the only real heat access from the top of the pipe.
    I may well do, there are 3 more radiators downstairs all with their tails at jaunty angles........
  9. Benway
    Benway
    18 Oct 2005
    294
    Thanks Received:
    15
    Essex
    Country:
    Getting there.......
    ..... I think.
  10. Sponsored Links
  11. Servotech
    Servotech
    19 Nov 2009
    360
    Thanks Received:
    47
    Nottinghamshire
    Country:
    And this is always the problem with repairing CH leaks under concrete floors.
    You chop up the floor find a leak, repair it, re-fill system only to find yet another leak and on you go.
    Also whilst you are chopping up the floor you are also possibly creating other leaks.
    A proffesional plumber would always want to re-pipe it and surface mount that pipework.
    Is this possible?
  12. ajrobb
    ajrobb
    23 Jan 2010
    1,656
    Thanks Received:
    163
    Sussex
    Country:
    What sheathing is there on the copper to protect it from corrosion in concrete? I thought bare copper should never be buried in concrete.
  13. MickyP10
    MickyP10
    22 Feb 2006
    206
    Thanks Received:
    9
    Country:
    Just noticed those high heels in the first pic. Think wifey probably speared the pipework!
  14. htgeng
    htgeng
    1 Jun 2004
    2,123
    Thanks Received:
    99
    Lancashire
    Country:
    How do you know its the wifey :eek: Seriously though, those are real bunion makers! She wouldn't be going anywhere on my lino :p
  15. Benway
    Benway
    18 Oct 2005
    294
    Thanks Received:
    15
    Essex
    Country:
    Fiancee! I can still change my mind!
    At least I know where to send the bill now.
  16. Benway
    Benway
    18 Oct 2005
    294
    Thanks Received:
    15
    Essex
    Country:
    Hopefully sorted.
    What's the usual commissioning period before covering up with concrete? Week? Month? (I will be using Denso tape)
  17. misterdubya
    misterdubya
    2 Oct 2010
    3,625
    Thanks Received:
    539
    Country:
    Looks a tidy job!
    Fill it up, get it hot and Bobs your uncle. Buy some rubber gloves and get out the denso.
    Mr. W.
  18. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
