Supply to Programmer
13 Sep 2006
Cheshire
When installing the supply to a programmer, I believe you need to provide a fused switch.
If this is installed vertically above the programmer, is it reasonable to route the outgoing HW and CH cables through the back of the metal box?
If not, how do the experts do it neatly?
Many thanks
does not need to be fused switch, just a fused connection unit.
it does not have to be above below to the right or left either, just some where close. (not the other side of the wall close)
never run cables through the fcu box other than the ones for the fcu
is fine or with a switch if you like
Thanks Breezer, now I even know what it's called :)
Having taken on a house where the previous owner has run cables at random angles and had a few near misses, I am now probably a bit too obsessive about keeping wiring in places where you expect it. But I'll take your advice and mount the fcu just off the vertical and keep the other wires separate.
If this is only a boiler spur and not the main heating isolator then that is correct. Although I would still prefer to see a double pole isolator or triple if modern boiler with switched/permanent live in its place.
If this is the main on/off fro the heating system then it MUST be a double pole switched fuse outlet with a 3 amp fuse in it.
