We moved into a new (old) house a year ago. It was built in about 1910 and has been heavily extended since (before we moved in).
The roof gutters are weird. Most drain into the 'main' drains, which go to our septic tank. One half of the roof drains down a downpipe which empties straight onto the soil at the top end of the house (the house is on sloping ground with a terraced garden).
Obviously none of this is ideal. We did have a problem with ground water coming up in the 'basement' (actually 'a garage under the house, lower down the hill') last winter, which may have been exacerbated by the unterminated drain at the top of the house.
Another "problem" is that the bedrock here is literally about 30-40cm underground. That means that putting a soakaway in wouldn't be a trivial job (and it wouldn't soak away very well).
So, my current thinking is - divert all the downpipes into water butts which we can use for watering the garden and potentially washing cars (after filtering), and simply divert any overflow from them onto our garden about 2 or 3 metres downhill from the house.
Even installing proper underground pipes would be tricky because of the shallow bedrock
I'm not sure what buildings regs says about this, or if there are any better suggestions?
