I want to insulate under ground floor. It is a suspended floor with wooden beams. I have access form the crawling space so I wanted to use rockwool. The problem is the distance between the beams. It varies between 61-64 cm so the standard 60 cm rockwool boards are not wide enough for tight fit. If I cat them across then I either have a lot of leftover material or it gets difficult to squeaze and fit it between the beams two pieaces.
Any ideas how to make easy insulation between the 61-64 cm distance beams?
