Does the radio go completely blank with no lights on, or does it just loose the radio station/phone connection? If it goes blank, you have a bad power connection.
If you only loose the station and all your settings have not changed, you could try disconnecting the battery overnight, but make sure you have the RADIO CODE before you start. You need to put the code back in after reconnection to get the radio back up and running.
