sWIFTFLOW 75/80 COMBI BOILER
8 Apr 2011
Merseyside
I need an obsolete part for Swiftflow 75/80 combi boiler - its the inner case cover can anybody help
cheers
yes mate, get a new boiler, these boilers can fire up without the fan running due to aps getting stuck :shock: Danger!!!
thanks for the warning - it has been isolated, just needs this part so i can re commission seems a shame to pay for a new boiler just for the sake of this missing cover
which bit do you need? hard to know from the description. I scrapped a load of these i took out a few months ago, but did give one away to be used as a fault finding test boiler. Not sure if its still in existence but could maybe find out
the inner case cover has the small window in it for the pilot and has 4 bolts. You remove it to get at the fan assembly. The combustion chamber is separate..
:shock:
The inner case cover is what makes this boiler room sealed !
without it the boiler is ID, stop tinkering and turn the gas off to boiler FFS
Dont you realise that you are not qualified to recommission the boiler?
Thats the inner combustion chamber cover!
An obvious question is where has it gone?
Is it a second hand boiler that you are trying to reuse? ( Illegally ! )
i if rember fan runs permantly and it draws air in if fan then does not burner light not enough oxygen piolt goes out
it is not a second hand boiler its one which has worked fine for 15 years the part was removed when the fan assembly was replaced and not put back its now gone missing - yes i know this is crazy but before i get a new boiler i thought i try a long shot and see if any one knew where i could get this obsolete part
