Switch Fused Connection Unit Help
6 Mar 2004
Hi all,
I am use to the S fCU usually having Load and Supply on it at the back.
On this one from TLC it has In and Out.
Can you clarify which one is Load and which one is supply. It doesn't have any instructions.
Yes and i know it will be a simple answer that i will never forget.
If i were to guess, which i wouldn;t with electrics i would say that In was the supply and out was the load.!
andemz said:
Hi all,
in is in (feed/supply) and out is out (load)
Wouldn't have mattered much if you'd got it wrong, and if the FCU has a neon, it would have been obvious...
