switch Info
View media item 93048
NC is black
NO is blue
COM is brown
the connections will be marked on the back of the APS, you can double check the colours/connections in the instructions.
You should not be accessing the APS location inside the combustion chamber let alone replacing it.
We are not permitted to give DIY gas/combustion advice here.
So the only advice is to get a competent engineer. If you give your post code then possibly someone on here may be able to attend.
Tony
hmmm u do know that this model/make has a unique in domestic boilers (maybe ?) air proving system/set up ?????
The forum rules ( which by posting you are deemed to have read and accepted ) are very clear that we are not allowed to give any advice on gas/combustions issues which should always be addressed by an RGI.
It makes no difference who fitted the boiler.
Ton y
