Switchmaster 900
12 Sep 2006
Sussex
Hi all. I`ve recently moved into a house with a switchmaster 900 hot water and central heating controller. The central dial has stopped turning but I`m having trouble finding a replacement, for the whole unit thatis. Anyone got any suggestions - I`d prefer a digital unit if possible. Thanks in advance.
Well, I don't think there's a direct replacement it has a tall narrow backplane which isn't in use any more
I might have a S/m 900 lying about, I don't know
Thanks for the prompt reply Raden. I suspected I might have a problem with this as a couple of plumbers I have spoken to have been a bit reticent about tackling it. If you have a spare I`ll happily buuy it off you but you`re not exactly in my neck of the woods-unless you were on holiday when you registered!
sm900 is 138h x 83w
Danfoss 102E7 is 136h x 102w
but you can only use it if you aren't using your terminal 4 - HW off.
Otherwise any modern programmer would replace yours, not hard to change the wires about.
I'll take a look tomorrow
I have a S/M 905, but not a 900
does anybody know the difference ?
I can't remember
Raden - both 900 and 905 are exactly the same bar the styling.
Thats not my vast knowledge at work, i just checked my wiring book :wink: .
OK, OP - I have one, where abouts are you, I'm in Watford (slightly north west of Jakarta ha ha)
