Hi, I've got a live power cable under the bedroom floorboards that served a socket downstairs that's no longer required (and I don't want to blank off and remain visible for tidiness). The bedroom floor is topped with laminate flooring. I have removed a strip of the laminate flooring and a small floorboard to pull the cable up from downstairs but cannot get at the source of the cable i.e. where it is spurred from. I can secure the cable end in a 30A JB under the floorboards (accessible by unscrewing a small board if required) However, further under the floorboards I can see that the spur has a join in it using a chocolate block wrapped in insulation tape. Is this acceptable as it is?
