Wendy house = children playing in it.Hi
Im wanting to run armoured cable from Wendy house to terminal box inside house to a twin + earth. But do I need to run a separate earth cable as well as the twin and earth to the terminal box so the outer armoured has separate earth connection to consumer unit or can I connect outer armoured braid and inner earth to the single earth in the twin and earth back to CU. i.e can I run single twin+ earth from terminal box to consumer unit or do I have to run 2 separate cables[/b]
Not much of a friend if you are asking him to lie on official documentation for you. You could at least have the decency to ask him how you should do the work he's going to pretend to have done.I have a friend who is a NIC approved supervisor but he too busy to do install but will energise test and issue Certificate etc.
So who will sign for design and construction on the EIC?
What about Building Regulations approval?
