Do these need to be fitted on all baths, even if supplied by a combi. Or is it still just for stored hot water? Thanks
No, it means that once installed, the way it’s preventing exceeding temperatures (usually a thermostatic mixing valve - TMV2/3) is provided upon when built, for example a new build, is maintained, and should be written in the building regulations part G3, the same regs that apply to the installation and maintenance of unvented hot water cylinders. They don’t apply to retrofit circumstances.Just interested:
Does the wording on the right hand side mean that after the building is erected, G3(4) no longer applies and/or
if not formed by change of use it does not apply in any case?
Interesting. Does it mean the water from a hot tap (no mixer, separate H&C taps) must not exceed 48°C? That's how it seems to read, but HW is usually somewhat hotter than that.No, it means that once installed, the way it’s preventing exceeding temperatures (usually a thermostatic mixing valve - TMV2/3) is provided upon when built, for example a new build, is maintained, and should be written in the building regulations part G3, the same regs that apply to the installation and maintenance of unvented hot water cylinders. They don’t apply to retrofit circumstances.
OK thanks, we live and learn!The system is designed to control the max temp that can be delivered out of the tap into the bath. It's to prevent scalding. In the case of separate taps/mixing taps, the HW must have a TMV inline to reduce the HW to a max of 48Deg, they're usually fitted below the bath.
Bath only, and they do need serviced, which they very rarely are.Does it mean the water from a hot tap
I was just thinking of bath hot taps, but I see what you mean.Bath only, and they do need serviced, which they very rarely are.
Not sure if it has changed but the TMV is supposed to be a cover all, with the bath being the dangerous bit, hence why bath only.But this appears to have changed?
The building regulations that these are applied to are from 2010.2015/2017 that it was just for storaged water. But this appears to have changed?
