My partner has installed a new Thermostatic shower for my daughter.
Gravity fed system with boiler new twin impellor salamanda shower pump at side of tank. Sussex flange etc all following instructions.
Cold water in header tank in loft.
The shower works fine Once Only and after it is turned off dribbles a bit (like emptying shower head or pipe)
If A second shower was needed say an hour/Day later the pump wont work unless bled from cold water pipe in loft, could this be an air lock, if so how do we clear it?
hope someone can help please.
Thank you
Kind regards
Thank you
Kind regards
