Thermostatic switch for 6kw portable air conditioner ??
plug in thermostat works perfectly!
the fan switch and cooling switch stay switched in the on position at all times unless manually switched off, so when the thermostat switches power back on the fans kick in then 10 mins later the cooling part kicks in and starts cooling the room until the plugin thermostat knocks the power back off at correct temp. So far running very well!
