I recently had a new boiler installed along with 3 new radiators and 1 moved. The one which was moved fed with a thin ( 1.5cm ) plastic pipe whilst the rest of the system is off a decent thickness of copper.
Now it takes that radiator much longer to heat up than all the others and the bottom doesn't seem to be heating up properly...
Is this a problem with using plastic/ a thinner pipe or is it not even a problem at all?
