    Dismiss Notice
Timber sizes and spacing for a monopitch roof on timber outbuilding
Discussion in 'Building' started by MrPlank, 14 Jul 2019 at 2:01 PM.
  1. MrPlank
    MrPlank
    6 Oct 2008
    23
    Thanks Received:
    Berwickshire
    Country:
    Hi Guys
    I am building a garden room in timber and wanted to ask what size timbers I need to use for the roof. The span it will need to cross is 4 metres, the actual size is 4m x 7m, the monopitch of the roof will be 4 degrees. Will using smaller spacing mean I can use slightly smaller sizes or is this irrelevant. I intended to use 400mm spacing. I had planned on using 145x 47mm but recognise that this is not going to be good big enough, the roof covering will be cladco box profile. As always any advice greatly appreciated and I hope my wording makes sense.
  2. Notch7
    Notch7
    15 Sep 2017
    9,583
    Thanks Received:
    842
    Sussex
    Country:
    170 x 47 C24 is really the min.
    145 x 47 would sag a bit over 4metres, putting in more joists wont help with the sag, but it would somewhat increase load capacity, say for snow loading. Maybe 145 x 47 would be ok for box profile, its not particularly heavy.
    If the external building size is 4 metres, the clear span will be less, say 3.8m
  3. MrPlank
    MrPlank
    6 Oct 2008
    23
    Thanks Received:
    Berwickshire
    Country:
    Hi Notch7
    Thank you for prompt reply yes the clear span is 3.8 metres, the roof will have an overhang at the front of the building, the length of timber I intend to use is 4.8 allowing around 50cm ish over hang at the front. will 170x47 still be sufficient or is this detail not really rellevant.
    Thanks again
  4. Notch7
    Notch7
    15 Sep 2017
    9,583
    Thanks Received:
    842
    Sussex
    Country:
    no the overhang is irrelevant -what counts is the clear span.
  5. tony1851
    tony1851
    23 Feb 2012
    8,972
    Thanks Received:
    1,331
    Manchester
    Country:
    More joists would reduce the deflection of the individual joists because each joist will then be supporting less load, which proportionately reduces deflection.
    Additionally, deflection is only a 'serviceability' issue and not a structural problem.
    If there is no plaster ceiling, and if the steel sheets are full-length, the deflection may be of little consequence, 6" x 2" @ 300-350c/s would be fine.
    • Thanks Thanks x 1
  6. MrPlank
    MrPlank
    6 Oct 2008
    23
    Thanks Received:
    Berwickshire
    Country:
    Hi guys
    Thanks for the responses, the box profile sheeting will be full length and the internal ceiling will not be plastered, I intend to finish it in 10mm ish softwood cladding.
Loading...
Share This Page
