Hi All,
I'm newbie here...to the forum and to the UK! Currently renovating a house and have been coping well on how things are done differently compared to the States, but I am at a loss when it comes to raising the kitchen subfloor.
The current floor is a concrete slab with no DPM (based on the age of house), aprox 150mm below the finished dinning room floor. I would like to raise the floor to eliminate the step down and prep for plywood (perhaps hardiboard) then tile finish. As this is the kitchen I would ideally run the utilities (CH, H&C water, gas and electric to the boiler and other appliances) underneath.
Considering the construction of a suspended joist floor requires a minimum of 150mm void below joists and and air vent bricks this is not viable. I am considering Polystyrene (jablite or similar) floor slabs however am not too familiar with it. A number of questions regarding its use.
1) This product is structural on its own and doesn't require any additional support, correct ?
2) Is it able to be secure to the existing slab to prevent lateral movement? Any fixings would comprise the DPM necessary underneath. Will the poly and DPM react to adhesives? If the poly can't be secured, it stands to reason the plywood on top and tiles wouldn't be restricted as well? This would result in less than ideal surface for tile.
3) Can utilities be placed underneath? Specifically hot water and central heating pipes?
Do folks have any thoughts on using poly or the best way to raise the floor, insulate to building regs and sufficiently 'bury' the utilities? I'm interested to learn what I may be missing.
Thanks in advance for your insight!
