Toilet
13 Apr 2010
London
Hi All
The loft conversion continues, another problem. Tiled floor is down, shower tray in and now need a toilet. Prob is the guys that fitted the soil pipe have left it at 190mm center and most toilets are 180mm, any ideas?
Cut it close to the wall which might be a bit lower, then use an extended straight pan connector.
If you are absolutely stuck at 190mm and can't alter it, it won't make a huge difference, the water level will just be slightly higher in the pan.
You could raise up the pan on something but that never looks good IMHO.
