Hi all,
In the bathroom I have a towel radiator like this one (http://www.tradeplumbing.co.uk/product.asp?itemid=68&catid=36). The problem is that one of the valves is very difficult to turn and is effectively jammed - it just about turns one revolution. Therefore, the radiator always stone cold and never comes on even though the other valve can be turned. Do I have to replace the valve completely? I have tried fiddling about with the valve and bleeding the radiator but this hasn't worked. Is it worth getting a plumber to do this, or is it easy to do. I'm not an expert but I guess I would do the following:
1. Shut down boiler.
2. Drain boiler down a bit as the radiator is upstairs.
3. Replace valve (do I need to use PTFE tape around the joints)
4. Refill boiler.
It is point 4 I am worried about. I think I need to use some anti-corrosion fluid but don't know how much or where I would introduce this.
4. Refill boiler.
