Hello guys, newbie here so be gentle......
Right...here goes.....every time i have to drain down hot water system in my house, 13 year old house 2 up 2 down, when i reinstate the hot water i get massive air lock...i clear it out with the cold forced into hot tap via taps under the sink.
It always works after some gentle persuasion.
Only this time after draining down and then getting rid of air, all taps work ok.
Except my power shower.....
Fitted last September.it has worked fine, no problems, until this last drain down.
I have stripped out filters...clean....i have looked at check valves in the shower itself on the inlets..again ok.
I get hot water up to the check valves and a small purge of warm water will occasionally pump through whilst i run the shower.
I have gone through the original commissioning steps as required by Triton instruction.
Again no hot water.
Any ideas guys?????
Again no hot water.
Any ideas guys?????
