    Dismiss Notice
triple control thermostatic mixer 3 yr old cold water only
Discussion in 'Plumbing and Central Heating' started by loafer, 23 Aug 2012.
  1. loafer
    loafer
    16 Feb 2006
    237
    Thanks Received:
    7
    Sheffield
    Country:
    http://www.screwfix.com/p/swirl-ess...rmostatic-mixer-shower-valve-w-diverter/24674
    one of these as listed on link above
    installed 3 years ago (rotherham) medium water hardness
    now only gives cold water!
    presume that cartridge has been adversely affected by scale build up.?? no scale inhibitor/reducer fitted on either cw/dhw system.
    If this is likely.... how easy is it to remove the cartridge to descale and or replace?
    I have removed the cover plate heads and handles but given that the access around the tile cut-out is severely restricted, can anyone recommend or suggest a "plan of attack"
    I can just about get access to the cw and dhw entry points as the are on flexi braided hoses. I can cap these off whilst work is ongoing and double check that the issue is not a failure on dhw supply. Issue is removing and descaling cartridge (vinegar!?) or getting a new 1???
    http://www.facebook.com/?sk=welcome#!/?sk=app_2305272732_2392950137
  2. DIYnot Local
    3 Sep 2019
    Country:
  3. Sponsored Links
Loading...
Share This Page
