Triton Opal
20 Feb 2012
Yorkshire
my triton Opal 10.5kw has recently started to get colder, the pressure is the same but the temp of water has dropped a lot to just about being luke warm when turned right up. shower power light is on and no pressure warning light on - any ideas?
Then you need to check both elements are getting 230v when the shower is on high heat setting.
This is with shower running. so be careful.
If so check the resistance of both heat elements.
