Tumble dryer vent cap for when theres no dryer! ????????????
8 Jun 2010
Sussex
Hi all. wasnt sure where best to put this so thougth I would put it here! I am in the process of building my back porch which will form a sort of utility room....
We would like to put a tumble dryer exhaust vent in the wall to future proof it (we currently have no dryer) however would rather that this vent hole is not permanently left open! - which would cause a bit of a draught!
Can you get a 'cap' that will seal off the vent hole when it is not in use? Ive looked around and cant seem to find anything! Just a plastic plate or something is all I'm looking for....
it will sit above a worktop so will be a bit of an eyesore left open, not to mention compromising my insulation etc! It wouldnt count towards ventilating the porch either as air bricks are going to be used to do this!
Any pointers / info would be greatly appreciated!
hi thanks for the suggestion. I had thought of that however that is for a 110mm pipe. I believe that if I use a kit like this (http://www.screwfix.com/prods/11703/Heating-Cooling/Ducting/Manrose-Tumble-Dryer-Kit-100mm;jsessionid=I0SCR12RGTQQMCSTHZOSFFI) then the standard size is 100 mm.
do you recon I could just use standard 110mm soil pipe with a plug, and a vent cover thing screwed to the outside?
Expanding foam? can be cut away when needed. Cover it with a louvre vent.
