TV surpressor for Baxi Boiler
10 Feb 2007
Cumbria
I have a Baxi Bermuda back boiler (christ not another one you say!).
It has the typical TV scrambler when it starts up. This is the gas valve, is that correct?
The Baxi part is 040884. What does fitting this part involve?
Cheers
on some it can be done with everything in position .
1 screw just above stat knob holding housing to tray. wiggle it free from bottom connection.
move to the side (bit of play on wires) the suppresor goes between the 2 connections on the gas valve that you should now be able to see.
Obviously turning power off first
you useed to get instructions with the part, maybe thats not the case now.
