I have recently purchased an old vw golf that has alloy wheels fitted I have found that the tyres was loosing pressure after about two weeks I have found that 3 of them is now not as bad but one in particular needs air every 3 or so days after looking at other posts on the subject and putting some soapy water on the rims I have found that they are leaking around the rim,
Will the spray tyre inflator stuff (not sure what its called) do any good?
How much should it cost to get a fitter to sand and refit the tyre?
Is it possible to deflate the tyre and use some sealant between the tyre and the rim?
Can I remove the tyre myself and sand and seal the rim? (I have good tyre levers and compressor)
Any other suggestions please
