Someone probably asked this before, but I can't find it. So I am asking for your help.
I have converted a barn and installed the underfloor heating tubes a while ago. The house is upside down with the bedrooms downstairs and the living area upstairs. Downstairs there are three rooms and a hall and two bathrooms - the temperature is quite stable. Upstairs the temperature is a bit variable with the sun and the thermal mas of the underfloor heating is a little less than downstairs.
I want to install an ASHP - I've done my calculations and 7.5 to 8kW should do the job. I'm thinking one manifold for downstairs and one for upstairs and two temperature zones one on each manifold. I'm not sure how to do this and have some silly questions... Sorry!
Do I use actuators on the input of the manifolds each controlled by something. The thermostats need to talk to the heat pump as well. How does that work?
Do I actually need a buffer tank? I think I probably do, but a small one.
I'm actually quite good at normal plumbing and electrics, but I've never installed a heating system before - how hard can it be! Famous last words.
Any help would be received gratefully.
David
David
