Under sink water heater installation problem (a right pain in the Ariston)
12 Aug 2014
Argyll
Hi there, I've recently installed an under sink water heater with expansion controls. I've got the mains going through an isolator valve then into a pressure reducing valve. This seems to be where my problem is. When I open the isolator valve the water flows for a few seconds, the taps work then "THUNK". The water is cut off. If I open the isolator very slightly it works for a bit longer but soon cuts out again. Could the mains pressure be too low or high for the PRV?
Thanks for any help. The local plumber here has recently retired.
Is the prv installed the right way round? There will be a flow direction arrow on the valve body.
Ha ha! Brilliant. You spend ages threatening an inanimate object with extreme violence, cursing the manufacturer and getting ready to march down to Screwfix for a replacement and then you realise you're an idiot.
Many thanks, Elkato531
I've seen 'professional plumbers' put stopcocks on the wrong way round ...
