That's better, now shake hands and don't do it again.
If you'd have said that to begin with it would have saved time.Softus said:I don't know.
True, I haven't done this before, but why is copper pipe such a bad idea? Thanks.Bambergaspipe said:Don`t use copper, if you can`t afford proper underfloor heating controlled by a roomstat & a manifold at least use plastic pipe. I think you will come unstuck anyway because you can`t just lay it down willy nilly, the fact that you are considering copper for your underfloor heating shows how incredibly out of your depth you are.
You just said previously that you didn't know why the design was flawed? What makes you assume that I wouldn't like it?Softus said:I could tell him everything he needs to know, but he won't like it, and he says that he knows it all already anyway.
Yes you did - but you never said why it was flawed.Softus said:The very first thing I did was to imply, without a shadow of doubt, that your design was flawed.
Read it again.Softus said:Are you now conceding that you don't know all about the plumbing aspects?
Again, you never say what I'm doing to give you that impression nor did you offer any solutions to these "problems". I'm not prepared to converse with you any longer - I've only been on this board less than 24 hours and it already seems you go out of your way to be as unhelpful as you can be. So either take your bad attitude and get lost from this topic or point out the problems you can see and offer solutions.Softus said:You asked me why it was flawed, and I gave you my opinion, i.e. that you didn't know how to go about it.
Somewhere I got the impression that you didn't want to know. I still think you don't want to know, because you still haven't asked.Yes you did - but you never said why it was flawed.Softus said:The very first thing I did was to imply, without a shadow of doubt, that your design was flawed.
I've read both this:Read it again.Softus said:Are you now conceding that you don't know all about the plumbing aspects?
...and this:I don't have any problems with the plumbing etc.
... and they seem to be in conflict. I know which one I believe, but I don't know which one you believe.True, I haven't done this before, but why is copper pipe such a bad idea?
I disagree. I asked you specific questions that would have led to more information, with the clear implication that you hadn't thought about the answers to those questions.Again, you never say what I'm doing to give you that impression nor did you offer any solutions to these "problems".Softus said:You asked me why it was flawed, and I gave you my opinion, i.e. that you didn't know how to go about it.
That's a wide-ranging statement based on a 24 hour membership.I'm not prepared to converse with you any longer - I've only been on this board less than 24 hours and it already seems you go out of your way to be as unhelpful as you can be.
Yes, but you might want to post it in P&CH rather than tiling.I'm prepared to start this topic afresh - are you?
The flow will be controlled by a valve; I'm not too worried about controlling the temperature of the water independently for that room. The system will be connected to the central heating in place of a radiator.Softus said:1. You don't appear to have designed in a mechanism for controlling flow and temperature of the water in the underfloor zone.
No, setting the temperature for the room isn't something I require; just a manual valve will suffice.Softus said:2. You don't appear to have designed in a thermostat for setting and detecting room temperature in the underfloor zone.
What I was planning was cutting a polysterene sheet to shape to fit under the pipework. Will this be sufficient?Softus said:3. You don't appear to have addressed the need for a layer of insulation under the heated floor pipework.
No, I'm not going to be pouring concrete on top; it will stay open. The insulator will stop the contact between the copper pipe and the concrete.Softus said:4. You've implied that you're going to pour concrete directly onto copper tubing, without any mechanical or corrosion protection.
Why is this? I'm prepared to use plastic pipes as Bamber gaspipe suggested, but what are the disadvantages and advantages to using them?Softus said:5. The use of copper tubing is wholly inappropriate for wet underfloor heating.
Thanks.[/quote
I guess that is a good enough reason... Thanks.Bamber gaspipe said:Plainly the advantages of using flexible pipe is that when you get to the wall at the end of your run you can simply bend the plastic & make your way back. Do that probably 20-30 times is easy with 12mm underfloor plastic pipes. Try doing it with copper over a whole room. Impossible.![]()
That would be entirely the wrong way to do it. The flow temperature from the boiler could be anything up to 80°C - very hot, both for any floor covering you choose, including tiles, and for your feet if the flooring gets anywhere near that hot.MyNameOnly said:The flow will be controlled by a valve; I'm not too worried about controlling the temperature of the water independently for that room. The system will be connected to the central heating in place of a radiator.
You said that the water temperature would be 45-55°C, but unless you have a manual blending valve, you have no way of achieving even that.No, setting the temperature for the room isn't something I require; just a manual valve will suffice.
No. No no no. No. No no no no no no no. No.What I was planning was cutting a polysterene sheet to shape to fit under the pipework. Will this be sufficient?
I'm confused by your use of the word "open", but wouldn't an insulator impede the transfer of heat?No, I'm not going to be pouring concrete on top; it will stay open. The insulator will stop the contact between the copper pipe and the concrete.
Bamber has since covered this point.I'm prepared to use plastic pipes as Bamber gaspipe suggested, but what are the disadvantages and advantages to using them?
The boiler is a combi, but the heating is never set above 55, it is generally ran at 45 degrees.Softus said:That would be entirely the wrong way to do it. The flow temperature from the boiler could be anything up to 80°C - very hot, both for any floor covering you choose, including tiles, and for your feet if the flooring gets anywhere near that hot.
Yes, although this temperature is set from the boiler - that should be okay shouldn't it?Softus said:You said that the water temperature would be 45-55°C, but unless you have a manual blending valve, you have no way of achieving even that.
Why no?Softus said:No. No no no. No. No no no no no no no. No.
Well, the insulator goes between the copper pipe (which I shall make plastic) and the concrete channel, it won't wrap around the entire pipe:I'm confused by your use of the word "open", but wouldn't an insulator impede the transfer of heat?
I don't think we're talking the same language. How can your boiler heat the house if the output temperature is 45°C?MyNameOnly said:The boiler is a combi, but the heating is never set above 55, it is generally ran at 45 degrees.
Compare the U value of sheet polythene with the insulation recommended by underfloor heating system manufacturers and required by the Building Regulations.Why no?Softus said:No. No no no. No. No no no no no no no. No.
Your diagram implies that you intend to apply tile adhesive straight onto the pipework.Well, the insulator goes between the copper pipe (which I shall make plastic) and the concrete channel, it won't wrap around the entire pipe:I'm confused by your use of the word "open", but wouldn't an insulator impede the transfer of heat?
It's not a large house, so that's all the temperature we need.Softus said:I don't think we're talking the same language. How can your boiler heat the house if the output temperature is 45°C?
Well, I wasn't going to be applying the adhesive onto the pipework, but there wouldn't be anything between the pipework and tile other than a cm or so of nothing. It seems this isn't a very good idea...?Softus said:Your diagram implies that you intend to apply tile adhesive straight onto the pipework.
In the unlikely event that you're right, I don't see how you hope to satisfy the Building Regulations, and prospective purchasers of your house when you come to sell it.It's not a large house, so that's all the temperature we need.Softus said:I don't think we're talking the same language. How can your boiler heat the house if the output temperature is 45°C?![]()
Have you found a floor tile manufacturer, or supplier, or installer, or an adhesive manufacturer, or supplier, who thinks that having pockets of nothingness underneath floor tiles is a good idea?Well, I wasn't going to be applying the adhesive onto the pipework, but there wouldn't be anything between the pipework and tile other than a cm or so of nothing. It seems this isn't a very good idea...?Softus said:Your diagram implies that you intend to apply tile adhesive straight onto the pipework.
To be very honest, I haven't. What do you recommend I use to fill in the channels with - perhaps a type of screed?Softus said:Have you found a floor tile manufacturer, or supplier, or installer, or an adhesive manufacturer, or supplier, who thinks that having pockets of nothingness underneath floor tiles is a good idea?
