Not sure if this should be in thi section, or Electrics, or Plummbing & Heating, but here goes anyway..........
I am doing a single story extension and knocking a load of walls around downstairs. All the rads are in poor positions, so i was going to re-plumb downstairs as well as move the boiler.
I have been toying with underfloor heating. Total area is about 75msq. I have costed it at around £2300 with 4 thermostats and 6mm insulation board.
I have been doing some research and I can only find old posts where people say:-
"it can not be used as a primary heat source" - which is what I was planning.
"it will cost more than gas"
"for the same cost as gas you will only get 30% output"
Is there any truth in these statements?
Has anyone got electric underfloor heating installed as a primary source of heat? is it ok?
Have things moved on a lot recently?
Should i stick with my gas central heating as I will still have rads upstairs and therefor need a boiler...?
Any help would be great.
Many thanks
Huw
Many thanks
Huw
