unequal pressure on hot and cold ??? bathfiller/shower mixer
16 Feb 2006
Sheffield
I want to put a combined bath filler/shower mixer onto bath replacing twin taps and replace the electric shower presently fitted. The bath filler/shower mixer I have in mind is a standard manual mixer not thermostatic.
the flow rate on the hot water measured off my bathroom basin (both on 15mm feeds) is:
20 seconds to fill basin off cold.. direct mains fed not cw storage tank
30 seconds to fill basin off hot water.. fed from hot water cylinder.
The hot water cylinder is located on the landing floor level same level as the bathroom floor. The hot water isolation valve (gate valve) is above the cylinder, goes up into the roof space and down again to the bathroom on 22mm copper.
Question is????
If I put a shower head above the bath is it likely that the hot water will struggle to feed the shower head??? (Negative head)
Will a manual mixer with cold water set low and hot water at max give sufficient flow other than a trckle of water at a reasonable temp??? say 38 degrees????
:confused: :confused: :confused:
WHAT YOU NEED TO CHECK IS THE DISTANCE FROM SHOWER HEAD TO THE WATER LEVEL IN YOUR COLD WATER TANK IN THE LOFT, THE GRATER THE HIGHT THE MORE HEAD OF WATER ,LESS THEN 3FT WILL BE VERY POOR,LOOK AT THE QUESTION WHERE A GUY RECOMENDES A VENTURI SHOWER
The hot water cylinder is located on the landing floor level same level as the bathroom floor. The hot water isolation valve (gate valve) is above the cylinder, goes up into the roof space and down again to the bathroom on 22mm copper. By the way.........the hot water distribution pipe must not be fitted with any service valve(gate valve) otherwise you may inadvertantly block the vent pipe and if that happens hot water will have no place where to expand!!!!
Question is????
Your supplies aren't suitable for a mixer. Venturi shower should be good.
