Hi
This is an odd request - but let me explain.
Alpha CB28 LPG Combination Boiler
The boiler has stopped working - no hot water and no central heating.
The fault finding page of manual point to two possible faults.
ONE
If the "B" light flashes every 5 seconds or so, and I think it said if you cannot hear the fan then it is either;
PC Board - test between MB36 and MB39 (I think its these numbers, haven't got manual here now).
Could find lots of MB's but not 36 or 39 (used a mirror and magnifying glass).
TWO
The circulating pump.
If the pump is not jammed replace the pump. The pump is not jammed it spins fine and semi clear water came out.
We have lived here 11 years and the pump has never been replaced. The boiler didn't seem that new when we moved
in so it's fairly old.
Around 20 years ago I had a pump go on me after 4 years after I installed a new boiler with lots of radiators, hot water
cylinder with immersion heater and motorised valves - best of both worlds - if either gas and/or electric is off, shower still
works - I loved that system with Aqualisa 60 foot head power shower pump.
Someone came out and checked everything I had done - didn't want to blow the house up on mains gas.
So it seems that sometimes pumps don't always last for long periods.
We had a service contract with British Gas for 3 years but stopped 2 years ago.
British Gas replaced a lot of things on the boiler including the heat exchanger AND I'm absolutely certain the PCB.
The PCB looks very new.
The fast blow fuse is okay.
On Friday I phoned as many Gas Safe engineers as I could, either they couldn't come out for over a week and
when they did arrive I'd have to wait for a pump to be ordered, if it turns out to be the pump
(I told them I thought it was).
On top of that, not one Gas Safe guy held the LPG ticket. So still couldn't come out.
We live on the South Coast, LPG is widely used, couldn't understand that local engineers wouldn't deal with LPG.
For medical reasons we need the shower up and running. We have an electric shower as well but that has problems.
So I had to make a decision, and have taken a chance and ordered a new pump on Friday for delivery on Monday.
Ordered: Grundfos UPS2 15-50/60 (130) A+ Eff. Domestic Heating Circulator 240V (replaces UPS 15-50 + UPS 15-60)
My old pump is a UPS 15-60 (130) so I'm hoping it will be okay.
OK HERE IS MY ODD QUESTION
Before I fit this new pump and scrape all the "red paint off the threads" I would like to see if it is
the pump that is stopping the boiler from firing up.
So do you think the following would work?
I leave the old pump exactly where it is i.e. with pipe work still connected BUT I disconnect electrics from OLD pump
and connect cable to NEW pump.
Holding the pump in my hand or rig up a platform for pump to sit on, when ready start to pour water into pump while my
wife "flicks" power on at wall switch ON/OFF very quickly so that I can feel if the pump starts to vibrate.
I would pour water in to pump so it doesn't burn out although I only need about a 'second or so' to know if it's going to work.
Of course I'd make sure that no water can reach any electrics and PCB board.
If I cannot feel the pump vibrate then I'll send the pump back and swallow the return postage.
Do you think this is OK?
We want to get a new boiler but this was next year, so don't really want to waste money on a pump if not needed.
I would treat the new pump while testing extremely carefully including leaving no marks on electric screw points, and
thoroughly dry it out.
Mad idea or what.
Just one other quick point- is there a way to "drain just the boiler" without draining the whole central heating system?
Any ideas or help appreciated.
Many thanks.
Stephen
ONE
TWO
Mad idea or what.
Many thanks.
Stephen
