Hi Guys,
Have a few questions on unvented cylinders:
- I have a flow rate of at least 20 litres per min on Ground level (worst case scenario based on my calculations). Is that enough to provide at least 2 showers at the same time on the 2nd floor? (approx 8m higher from ground)
- Direct vs Indirect - Is it preferable to have one over the other? what is the difference in running/installation costs etc?
- Cylinder will be located on 2nd Floor level. How much likely pressure/flow rate drop would there be at source of cylinder? height approx 8 metres with 22/28mm mm pipe feed.
Cheers
Cheers
