We have an unvented cylinder with a Horstmann Electronic 7 timer. The cylinder only serves a wet room which is very rarely used. The rest of the house is served by a Vaillant combi boiler.
The timer on the cylinder is set to heat up water 3 times per 24 hours, which I think it is the default. With energy costs spiralling, I would like (if possible) to reduce the time the water is heated, but also avoid creating problems with legionnaires due to lower water temperature or causing any short or long term damage to the cylinder.
Can anyone advise if there is a sensible 'minimum' setting I can use? I am happy to change the settings when we have people coming to stay (which is the only time the cylinder gets used these days).
Thanks for any advice.
