Some advice would be great. I wish to replace all my bathroom taps basin included.There are also other leaking taps the need attention. The problem that I have is there are now isolation valves near the taps. The system spec is a "Santon Premier plus unvented hot water system". The boiler a "Potterton suprema 50". There is a stop cock in the kitchen and a gate valve situated just before the cold mains supply to the unvented cylinder. What would the procedure be to drain this system. Is it a simple case of shutting off the mains supply to the property and to the unvented cylinder then opening hot and cold taps at the lower point of the property.I have noticed a draining point above the boiler.And what would the filling procedure be to avoid airlocks? The boiler ect will be turned off prior to draining. Your advice will be appreciated
