UPVC patio door wont lock even when open
18 Oct 2019
Hi all, I cant lock the door, the lever needs to turn a bit more but cant.
I have tried it with the door open so there is no resistance but the door still doesn't lock.
Any ideas please?
Either the cylinder barrel is sticking/not turning it the actual locking mechanism is broken. It may be one of the top or bottom points are stuck but my guess would be the actual ' gearbox ' . Post a picture up of the lock ' face ' .....top middle and bottom , may be able to identify it. If not it may need removing and measurements taken to identify the correct lock .
Better to have a gearbox failure with the door open rather than locked!
  1. With the door open...
  2. remove the screw that holds the lock cylinder in place - try the key and see if it can lock
  3. Take the cylinder out, check it will turn with the key etc. - if yes then...
  4. remove the handles and spindle then unscrew the locking strip from the edge of the door (likely philips or posidriv - gearbox may be secured to strip with torx screws)
  5. pull out the lock strip and gearbox from the door
  6. Measure the gearbox https://www.upvcwindow-doorparts.co.uk/how-to-measure-a-lockcase/gearbox
  7. Order a replacement (I was able to get an ERA one for mine for £16) and fit it when it arrives.
  8. while you're at it consider swapping out the lock cylinder for a 3 star diamond rated lock - or at least 1 star
