UPVC Window reseal
21 Aug 2006
Buckinghamshire
Hello All
do you have any advice on sealing around a upvc window that sits in a old box sash fram brickwork
the walls are damp around the window and i can hear the wind through a small bit.
what is the best way to reseal around this so fix the damp problem and keep the upvc window a little longer before i remove it and turn it into a box frame with french doors installed.
Easiest way is to rake out any loose material and brush out, then run silicone sealant into gaps and create a fillet round frame.
