Hi
I've a Ravenheat HE85T boiler, very similar to CSI85T model.
Recently, the boiler stopped working and red (overheat) light came on. I checked the thermisters, they were OK. The pump was not working, although there was 240V supply @ pump, so I've changed the pump.
Even after that, the symptoms are still the same. I put CH or DHW ON, the fan starts in low speed, the pump starts(I opened the big bleed screw and could see the pump running inside now) but the red light comes after 5-10 seconds..
There is no flame (looking through the window), so how does the overheat light come on? The fan does not seem to go full speed, so could it be fan or air pressure switch? Could it be some air lock but I thought the air inside boiler (drained a few times) goes automatically through air vents..
My worst fear is ignition control board (main PCB) and I hope that never comes true..
I hope I get some replies and many thanks in advance for that..
