I have purchased a 400L SLME to go in my extensions to provide
1) intermittent large volumes of hot water and a recirculating DHW loop for regular hot water draws.
2) Connection to solar via the bottom coil when money and time permit.
3) To supply heat to the CH loop in the original house (currently being fed from a combi which is to be removed when a new primary boiler is installed)
4) To supply heat to the CH loop in the new extension space
5) To supply heat for a small heat exchanger for a therapy pool.
6) Possibly to supply a CH loop in a modest tied flat to be constructed in the roof space.
My question is:
Is there any reason why each of 3) 4) 5) & 6) could not be considered separate circuits each having a pump, programmable timer and a thermostat?
This would make the installation and fault finding fairly straightforward.
All helpful comments gratefully received.
My question is:
