vailant ecotec pro 24 pressue problem
17 Oct 2011
Derbyshire
I have a vailant ecotec pro 24 combi that keeps losing pressure. We repressurise the system and its OK for hot water but when the central heating has been on it dumps all the pressure.
Any idea's
When you repressurize do you vent the rads ? Check for obvious leaks (rad valves etc) also check the copper pipe (prv) that should go out the wall. You may need the expansion vessel pressure checking as well.
