I have recently had to have the diverter valve changed on the boiler (originally fitted 2007)and then it was found that the pcb was faulty too - apparently a common thing in conjunction with the diverter valve.Now the pressure on the gauge keeps rising to 3.2 bar and so I asked the plumber to check it and he said it was either the ev needed recharging or the diaphragm had gone. No water came out when the valve was checked so we presumed it was in need of recharging. He simply pumped it up to the req pressure. This hasn't solved the prob and after looking at the FAQs on the subject on this forum I followed the instructions on how to drain the system through a drain valve on the rad and then recharge the ev , checking as it states in the instructions. This looked to have worked but again the pressure is rising. Any suggestions - is it the refilling knobs that are not shutting as in other posts on here ?
