Hi,I have a Vaillant Combi VCW GB240h its about 12 - 15 yrs old.The problem is the boiler loses pressure over time ( about 7 - 10 days at the moment ) this has always been a problem since it was installed but it used to be every couple of months between top ups.The only part i have ever replaced is the Auto Air Vent which is now leaking a small amount of water,could this be the problem ?Also the hot water takes ages to get to
temperature and once recently turned brown out of the tap.Due to the age of the boiler and the cost of parts and labour would it be better to fit a new boiler as i have seen the Ravenheat combi for £379 (are they any good)or do the Vaillant boilers have a longer lifespan than 12/15 years in which case it might be worth spending some money on it.Any advice would be welcome.
thank you.
thank you.
