Vaillant Compactcombi 242 eh - No heating
24 Jan 2011
Essex
Help - 14 yr old compactcombi Vaillant 242 eh
DHW - works fine
Heating - when switched on, fan runs, pump runs but no sparking hence no flame ignition
If I carry out a reboot i.e, with the Boiler on and the Heating/DHW switch on DHW only, I then switch off main power supply to boiler, then switch off the main switch on boiler
and then switch on main supply back on then switch on main switch on boiler then switch from DHW to DHW/Heating it then seems to runs as normal i.e fan runs/pump runs, Temp gauge goes up to approx 35/40c then flame ignition and flame modulation (this takes about 20 secs)
Has had flame supervision board, diverter valve, complete water section and servo control valve replaced in last 2 years
Any help appreciated!
Water pressure is............
Sounds as if the pump proving switch may not be workijng properly, dirt in pump or air in boiler? Have you drained the boiler or done anything else which is relevant without telling us?
Tony
Tony, thanks for your input
Pressure 1.0 bar constant
Had flame supervision board replaced 6 mths ago following identical prob
After thorough insp by combi engineer, he suggested possible PCB fault ashe could'nt put it down to any other cause, as Flame suppervision board seemed most likely candidate, it was replaced and boiler fired up on heating demand as normal
Started playing up again during v cold spell (xmas week) eventually fired up after several heating switch on/off attempts went back to normal for a few weeks and now needs total reboot each time to get instant heating function
Hot water supply is fine throughout all of this
Last drained down 10 mths ago while capping off old rad position
