Hi all apoligies if this has been covered before but I dont seem to be able to find any thing. I have a vaillant ecotec 28 pro that was fitted in oct 2012 ever since it was fitted I have been getting very random F22 faults code with 0.0 pressure reading. as this is understood to be low pressure I would then top up the system to around 1.2 cold and reset, the pressure gauge would then go through the roof and I would have to drain off. The boiler would be ok and perform as it should for random periods it could be a week it could be months then it would happen again. I contacted my plumber and he said I must have I seeping valve so I replaced all the rad valves in the house but the boiler still does the same. The plumber then said I must be putting too much in and I need to let it catch up ? Now I am no simpleton and I know how to use a filling loop he then explained that their is two gauges a electronic display and a mechanical one inside the cover so the next time the boiler shut down I checked the mechanical one and that was reading good in the green/blue but the electronic was saying 0.0 f22 so without filling I turned boiler off and back on and electronic went back to 1.2 and it went back to performing normally for months and we carry the cycle on. does anyone have any idea what is wrong as my plumber does not seem to have a clue.
