Hi all,
I am looking for some pointers to check everything is being installed correctly by my heating engineer.
I am having a ecoTEC plus 428 boiler installed along with the vSmart Controls including the VR66 wiring centre. This is replacing a failed Ideal Icos boiler, Boss Therm wireless stat and an ACL Lifestyle wiring centre. I will be keeping my Mcdonald Open Vented THERMflow Thermal Storage System in place: http://www.mcdonald-engineers.com/products/thermal-store.
This will be the first time my heating engineer has installed the vSmart and VR66 setup so I am looking for some pointers to help us both.
My boiler will be installed in the garage and the Thermal Store is currently in place in the upstairs airing cupboard.
It is planned to install the VR66 in the airing cupboard alongside the thermal store. As far as I understand the vSmart Gateway will also be installed here and will be connected to the 24V Bus connection on the VR66. A further 2 core cable will run from this Bus connection point to the Bus connection on the boiler. The existing cylinder thermostat will be wired into the NTC point on the VR66.
What I am unsure about is how the two pumps should be wired in, can these be connected to the VR66? A Grundfos UPS 25-60 130 and Grundfos UP 15-60 A0 are currently installed and wired in to the existing ACL wiring centre for the central heating and boiler flow.
Thanks in advance.
Kevin
Thanks in advance.
Kevin
